Charged RTX
Does anyone know where to find one. I have a rear cooler and I do not want to take any chances when I go to a 128 track.
LJ 452
I don't think they exsist. I think you're going to have to leave it or go 136" extension which may look a little weired. How close is your track to the heat exchanger as it sits now (121")? You may have to custom make something to get it to work.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
I run 128" track on my Apex Gt with 1.450" Megabite studs, NO tunnel extension. I find the stock '06 snowflap would get cought by the studs and get sucked in. I currently run the new style, rigid flap and get few scraches on the inside of the flap. If your current setup consists of a rear heat exchanger I would highly recommend an extension. I have yet to see someone comeout with a 128" extension, and would be willing to invest in one as well.
I also have an additional set of brand new 128" extensions if you are interested..
LJ 452
I think the 136" is what will have to be used. After all it's only what 6"-8" long anyway. A 128" would be about half that so basically pointless to manufacture. I'm sure if needed, you could shorten a 136 by a few inches to shorten it.
