12mm bar
from pioneer performance website:
RS, RX HEAVY STABILIZER BAR
The single most dramatic improvement you can make to the handling of your 4 stroke Yamaha! The stock sway bar on the on these machines is on the conservative (soft) side, the small diameter standard bar allows excess body roll when cornering. Our Heavy Stabilizer Bars will dramatically improve handling and reduce body roll compared to the stock bar. The increased diameter of the bars help to keep the sled flatter and more predictable in the turns. As the outside allowing you drive faster through the corners by keeping your skis and track in contact with the snow. A stiffer bar will also give you a softer ride than going to stiffer springs in front to achieve improved handling.
For '04-'05 RX-1, Warrior, RS Vector, Apex, '06-'07 Rage, '06-'07 Nytro, & Attak (LYX) owners we have a 12 millimeter bar to replace the stock 11mm bar (no other modifications necessary with both the 12 and 13mm bars), giving you improve stability and handling, or for the flattest possible cornering try our 13 millimeter bar. These sleds suffer from excess body roll and by installing a heavier bar will dramatically reduce body roll and improve handling. With either the 12mm or 13mm bar on these models they will directly replace the stock stabilizer bar without any other modifications.
We have three different diameter bars to choose from. Our 11 ('03 RX-1, '05 Rage) millimeter bar is for the rider looking for the best of both worlds, aggressive cornering, while maintaining a nearly stock (smooth) ride in the front. If you're looking for more you can upgrade to a 12 or 13 millimeter bar by adding the '04 & newer arms and bushings (arm part #8FG-2386L-00, bushing part #8FG-2386G-00 designed for the trail rider looking for the best possible (flat) cornering. The heavier bars make the front end flatter and more predictable when driving through the corners. A lot of time has been spent to come up with the correct manufacturing process to insure the durability of these bars.
P-S103......11 Millimeter Diameter Stabilizer Bar ('03 RX-1, '03-'05 RX Mountain, '05 RS Rage).....$59.95
P-S104A.....12 Millimeter Diameter Stabilizer Bar ('04-'05 RX-1, Warrior, RS Vector, Apex, Attak (LTX), '06-'07 Rage).....$89.95
P-S104B.....13 Millimeter Diameter Stabilizer Bar ('04-'05 RX-1, Warrior, RS Vector, Apex, Attak (LTX), '06-'07 Rage).....$89.95
8FG-2386L-00-00....Stabilizer Arms (75mm)(pair), required when installing 12 or 13mm bar on '03 RX-1, '03-'05 RX Mountain, '05 Rage....$79.95
8FG-2386G-00-00....Stabilizer Bar Bushings (pair), required when installing 12 or 13mm bar on '03 RX-1, '03-'05 RX Mountain & '05 Rage....$3.00
