13 mm swaybar
WiVector
Pardeeville, Wi
Have any of you guys put on a bigger swaybar from the stock one like a 13 mm. I heard about them on the rx-1's but how are they on the vector. Just looking to get rid of a little ski lift.
Thanks,
Welterracer put one on and loves it. I believe Mr. Sled did too. The claim is if you ride it hard it works, if you ride casually it tips.
thanks
does that adjustment make it alot harder to steer. also what way do you turn them to allow less transfer.
thanks :Rockon:
I like the weight transfer, it helps absorb bumps and gives you a better hole shot. The vector is not tippy like the RX1. What I do is squeeze on the throttle rather than hammering my thumb to the bar. Problem solved!!
the 13mm swaybar is night and day difference... I cant even but into words how much better it is... ITS UNBELIEVEABLE
as far as the guys saying that they still have ski lift ... Thats because they think you still dont have too lean... THE RS AND RX SLEDS WILL NEVER HANDLE AS WELL AS THE OLD LOW SLUNG TRAILING ARM SLEDS!!
welterracer said:
t
You're right on this. However....I've come to accept the fact, and have thus adapted. So I have no more issues in this regard. :Rockon:
Tfin said:
welterracer said:
t
I'm still having trouble adapting. Maybe the wife's Viper will stay.
