Does anybody know if camoplast ever made a 136, 1 1/4, 14' freeride track? or did they only make the 1.5' thanks.
snomaniac
The freeride is only one model. It is in a 1.375, 1.5 combo lug height. 14" wide,136, and 121 lengths. Great track. 136 is hard to find, they don't make them anymore from what I've read.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
there is also a 144" model. They have quit producing both the 136 and 144 lenght versions and both are hard to find ( but there are a few in the wild yet )snomaniac said:The freeride is only one model. It is in a 1.375, 1.5 combo lug height. 14" wide,136, and 121 lengths. Great track. 136 is hard to find, they don't make them anymore from what I've read.
Hey guys thanks for the info I did manage to find a 136 freeride in very good condition. It was just listed as a 1 1/4 so I was just curious if they had actually made one that size or if the person who had it measured it a little different then they do at the factory. cheers
Jeremy
jason4570 said:Hey guys thanks for the info I did manage to find a 136 freeride in very good condition. It was just listed as a 1 1/4 so I was just curious if they had actually made one that size or if the person who had it measured it a little different then they do at the factory. cheers
what part of ther NT are you from ??? Yellowknife. post some pics of your creation when your done !!!
Hey Jeremy I'm in Hay River. I'm also going to try a 136 by 2 and see how that works, I'll put some pics on when it's finished. Seen the video of you sinking your sled... that couldn't have been very fun, good video's, I never would have thought a phazer would go so good on water.cheers
Jeremy
For some reason if you try to go straight you will zing out but if you always keep one ski in the air and always carving you'll never have a problem. the reason why I sank was you know the two 10mm bolts and the allen head bolt holding on the lower side panel ? I only have the front 10mm bolt, the rear one is not usable due to a good wipe out last year. the front bolt rattled out and as soon as I hit the water, water hit the clutches right away because the panel flew open and alaowed water in. Just wait till next summer man !!!
UP bushman
Yes for you Venture Lite riders the Spindles are wider and the Kits will be specific to your model. The Mountain & Trail models have the same Spindle but different width ski spacers and shafts. Just specify model year and type FX, GT, RTX, MTX and so forth if interested thanks.
- 16K
