Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yamaha GYTR front shocks
I thought I was closer to 13" because the end of my tape measure is where my cut and weld is
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yours looks really great btw, did you buy the pipe size I said?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Ok I see how you were measuring it now. Ya I think yours should work. I added a 9" piece in mine but from the front weld it would be about 14" and when I fully compressed my skid with no springs on it it had some space left.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
what would be the easiest way to compress the springs? ratchet straps? or just taking the tension off of them?
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
yes, if you look close enough you can almost see the 2 welds. one meeting the end of the tape measure, and the other between 8-9"
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Thanks.Yours looks really great btw, did you buy the pipe size I said?
Well I finished it up last night at just before midnight and got it loaded on my dad's truck for him to take out to the cottage this morning. Sorry to anyone in west Winnipeg last night if I woke you up trying to load it at midnight.
It was a real fight to get that rear axle in after installing the skid, the new track is still fairly tight but should hopefully stretch out a bit.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
I'd take the tension off. I tried a ratchet strap one time and it ended up bending the ratchet part.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Sick extension! Looks great. Sadly we have been getting nothing but cold dry weather up here and no snow.. so I haven't had deep enough snow to really push the 136" to its limits. It's a crap winter in southern Ontario! Next project this summer is new wider skiis for the phazer! And might go back to stock exhaust.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Thanks!
It's not much better I'm Manitoba right now, +2 out and not much snow on the ground but there is some in the forcast.
Regarding skis I'm running MTX skis from an 09 Nytro and really like them. I've used Syldogs and they are good but I found them a little bit hard to handle in crusty snow. I also have a Skinz skid plate which helps with floatation.
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Where can I find this skid plate?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
It's made by Skinz Protective Gear http://www.skinzprotectivegear.com/info/distributors.html. But I bought mine from Royal Distributing.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
These guys have it, http://splashndirt.ca/catalog/ProductGroupDetail/2456/skinz-protective-gear-float-plate
I bought mine from Royaldistributing but can't find it on their site now?. The float plate helps a TON on the phazer. Voda when did you order yours? I got mine from Royal but it was a few years ago.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Forgot to add that yes I used your sizes, in imperial it's basically a 1" ID with a 7/8" OD and then a 7/8" OD bar slipped inside.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
Also from Royal but maybe 4 years ago. I did contact Skinz because I was missing the stickers that were suppose to come with it and they were very helpful and I think they will sell direct.
