Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
- 2018 Yamaha Sidewinder 137 XTX SE
Anybody running this track with a tune? If so, can you please tell me what gearing, what tune HP, what clutching components, etc? Any belt issues?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I ran it year 1 with powertrail tune, 21/41 gearing, stock secondary shimmed, STM 60ys weights and ulmer pink primary spring. Zero belt issues, 109.9 GPS on snow.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Thought you don’t come on here till October! lol
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
That doesn't seem very fast. I am getting that without a tune and I am a big guy.I ran it year 1 with powertrail tune, 21/41 gearing, stock secondary shimmed, STM 60ys weights and ulmer pink primary spring. Zero belt issues, 109.9 GPS on snow.
DMCTurbo
- Nov 12, 2005
Congratulations!!
If your running 110 GPS with a stock tune and a 1.75 back country you have a good one!
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
Thanks...I think!!!
I am going by speedometer. Some light clutching done. I am thinking of tuning but you are leaning me otherwise. I can't swear 110MPH but I think I remember 112 MPH on speedo. I know 107 MPH isn't a problem.
I was hoping for 120 plus with a 270 tune, exhaust, cold air intake, clutching etc....
DMCTurbo
- Nov 12, 2005
Ok you can't compare speedo speeds to GPS speeds.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
I wonder what is a common top speed with 270hp, CAI, EXHAUST,CLUTCHING etc... with a LTX? And what sort of speed reduction does the Backcountry 1.75 give this?
The Backcountry track is a good track but is it worth the top end hit?
Depends on the driver I suppose.
DMCTurbo
- Nov 12, 2005
10 mph minimum
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
A 1.75 backcountry track and top speed is a bit of an oxymoron.
The real question here should be, how long will that 1.75 track last running over 100mph?? My guess is not long. If it was me, and I wanted/needed that track, I would run the stock cat gearing at the most. Would be alot of fun up til top speed.
I know the backcountry track is more durable, but my brother has a snowcross Le viper that came with the 1.75 snocross track. What a POS for trail riding. Vibrated like an animal and only lasted 1200kms.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I’m putting a 1.75 Backcountry under my 129 turbo Viper RTX this fall. I’m still running the stock 24/50 gearing. I’m sure it will be an animal! But I’m curious how it will affect top end and the longevity.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
My BTX 153 with 1.75 21/41 gears TD max 17 it has hit 120mph it shouldn’t be a problem on a 137 1.75 pending conditions of course
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
110ish on speedo here with my 137 1.75
I’m sure I could have seen a few more mph if I had more room. But above 100-105ish it just creeps up slowly. Sure gets to 100 in no time tho. Sled is all stock and I’m also talking dream-o-meter speed not gps. I’m sure with a tube 120 could be had.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Stock tune mine would run on average 110 mph on the trail.
21-41 gearing.
Hurricane 270r tune I have run 123 mph on the trail with Backcountry 1.75.
Speedometer.
21-41 gearing.
Speedometer.
Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
Anybody getting some miles on using this track? I'm currently fighting some clutch heat myself and I'm on my third belt after 1200 miles, lol. I really want to get this figured out.
I'm currently running Dalton Blk/Green with Dalton DTAY 1 in primary, and a Cat Green with 33/35 helix in secondary. Thunder rollers in both clutches, Offset is 57.2mm, 8DN belt, Thunder belt adjuster which allows float. I'm tuned with TD map bundle but only running the 250 right now until this clutch heat issue is figured out. I run hard corner to corner with lots of 70mph plus trail cruising, a few WOT squeezes here and there, I'm not interested and top speed. I also changed gearing to 24/50 from 21/41.
I'm considering going back to stock set up and bring my offset back out a bit to pin point the issue. Any ideas? I have other weights and secondary springs I can try as well.
