DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Yup I initially installed my drivers and suspension without the track a few times measuring and getting the drivers setup perfect. Once I put the track in I probably took everything in and out 4 times getting everything lined up. I'd say no 2 sleds the same to be honest, if you want it perfect.The measurements are in service manual if you have one. A good starting point. DMC likely had his shaft out a few times getting it perfect as each sled can be slightly different if looking for perfection.
I agree...getting the drivers lined up usually takes a few tries and is a real pain if you want to get it right but there are only two ways to do something...the right way or the wrong way.Yup I initially installed my drivers and suspension without the track a few times measuring and getting the drivers setup perfect. Once I put the track in I probably took everything in and out 4 times getting everything lined up. I'd say no 2 sleds the same to be honest, if you want it perfect.
