Fasttrax
Wanted to put a 1.25 studded on my 17XTX but discovered that they dont come in 141" Wondering about a 144" track. Would I have to extend the rails or could I install bigger rear wheels to make up for the slack. Anyone?? Thoughts??
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
1989 Sno Scoot (red)
1989 Sno Scoot (blue)
1995 Vmax 500 (black)
1995 Vmax-4 ST (black)
2003 Rx-1 Mtn (black)
2016 VK Pro
2016 Venture TF
- Happy Valley - Goose Bay
- YOUTUBE
- Mokami
After loosing paddles off of my 03 Rx1 151” Mtn it was suggested to try using a Nitro 153” track. At the same time I installed anti-ratchet drivers and my track adjusters in the rear where enough to compensate. Granted going 2” longer isn’t quite going 5” longer like you are intending however, if you try going with larger rear idler wheels, keep in mind they will also have to be raised in some way to keep the edge of the wheels in line with your slides. Just mounting larger ones in stock positions will be asking for that track to slip off to one side in a corner at some point. Especially the grip of a studded.Wanted to put a 1.25 studded on my 17XTX but discovered that they dont come in 141" Wondering about a 146" track. Would I have to extend the rails or could I install bigger rear wheels to make up for the slack. Anyone?? Thoughts??
Fasttrax
My mistake on the thread....should of read 141 to 144After loosing paddles off of my 03 Rx1 151” Mtn it was suggested to try using a Nitro 153” track. At the same time I installed anti-ratchet drivers and my track adjusters in the rear where enough to compensate. Granted going 2” longer isn’t quite going 5” longer like you are intending however, if you try going with larger rear idler wheels, keep in mind they will also have to be raised in some way to keep the edge of the wheels in line with your slides. Just mounting larger ones in stock positions will be asking for that track to slip off to one side in a corner at some point. Especially the grip of a studded.
Fro-1
- Mar 2, 2009
- Labrador, Canada
- 1982 Bravo (red)
1984 Bravo (blue)
2016 VK Pro
2016 Venture TF
- YOUTUBE
- Mokami
If you’re sled has the window drivers you might get away with track tension bolts for that matter?My mistake on the thread....should of read 141 to 144
You will have to change the drivers as the 141 track is 3.00 pitch
Fasttrax
Thanks for reply. Just got off the phone with Camso and the 144 doesn't come 3" pitch and I really dont want to change drivers. Plan B it is...You will have to change the drivers as the 141 track is 3.00 pitch
