Good info and well noted. I am NOT using the LTX shocks in any case.The front skid shocks are different length between the XTX and LTX. Check out page 8 in the 2014 service manual. looking at the dimensions I would try the LTX shock first because it has a shorter collapsed length and make sure it hits the rail bumpers slightly before it fully collapses.
You probably already checked the center to center dimensions between the arm mounting holes on the rails to make sure they match the XTX, but thought I'd mention it. If the LTX hole spacing is different, you may encounter some geometry problems.
I used a set of XTX rails to find the locations to be sure the new mounting point were right on or damn close... its a trial so it may or may NOT work. From my experience with building and fitting skids in all kinds of sleds, I am pretty sure this will work.
Studroes144
- Oct 30, 2013
How did this project ever end up?
I have ridden in twice and she rides awesome on the trails that I did get to ride on... and handles like a race car. I just need more time on it.
Studroes144
- Oct 30, 2013
Did you ever get a chance to do a weight comparison? I've never heard exact numbers but have heard from several different people that the standard 141" uncoupled skid is pretty significantly lighter than a 129 or 137..15-20 pounds is ringing a bell.
I did not weight them. Next time I pull it out I can. I was more keyed on the ride of the XTX and the none coupled handling with no ski lift.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
It would be cool to get a parts list on this swap after you get it sorted out.
Ride On
- Jan 26, 2015
- Burlington, Wi
- 2015 Viper LTX LE
Damn it! And a price list
Once I get enough testing I can work the data up for the conversion.
Ride On
- Jan 26, 2015
- Burlington, Wi
- 2015 Viper LTX LE
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Come on Tom, parts list please.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
MAYBE Tom built a prototype for YAMAHA and can't release part numbers till March 1 st. Let's get that going
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Tom is most likely headed to or is at the Manitoba ride. Will only have wifi while in Canada if his phone is like mine when I'm there.
You are correct. Busy busy.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Are these just bolt on parts, or some cut and grind, weld and beat into submission with a hammer?You are correct. Busy busy.
You will need to drill a few holes in the LTX rails to except the bolt on parts.. thats about it. I will work on some info this weekend and pictures.
