13mm Sway Bar Install?
viper7mi
Michigan
Can someone help me with the directions to install the 13mm sway bar into my Attak?
Thanks, I tired to find it with no luck. I know there is directions out there.
ITs pretty obvious if you look at it. Remove the collar on one side and slide the bar out. Put the new link on one side of the 13mm bar and slide the bar back in and then install the last link.
Its easier to say then do but there is nothing really technical you need to watch out for.
Have to remove bolt completly to slide off though. There is a groove that the bolt sets in which is why it needs to be removed.
