Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Couldn't measure fault on this connector, the cover didn't have a scratch, but guess I could disconnect and take it for a spin. Only blown the fuse while driving anyway. ThanksThe wires run inside the tunnel under a very thin sheet metal guard. This is a bad spot, if the guard gets crushed it will short out the tail light wiring.
Remove your seat and on the left side there’s a connector for the wires going under the tank. Unplug it and see if the fuse still blows.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Intermittent short to ground, more than likely a wire rub through.
There’s really no way to find it with a meter because it’s fine most of the time. Very hard to find these types of issues.
Your best bet is to read the schematic and unplug things the Tail light circuit powers powers until the issue stops. The problem is the Viper electrical drawings aren’t legible because Yamaha has done 180 degree turn and the manuals are garbage.
I would remove the gas tank and check the wires where they go through the tunnel. Look for smashed wires under the tank.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Any luck?
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Just got my ecu back from raising rev limit, will try tomorrow. I'll keep you posted.Any luck?
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Problem solved! Had the display on a heated floor for a few days, connected everything and went on a trip, fuse still intact.
How do I keep my display condensation free? Also I did a headlight delete without any kit, great result.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Let’s see that delete broheim
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Couldn't upload a pic... There are some restrictions to size on uploadsLet’s see that delete broheim
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
You need the app photo resize. Just pic your photo from your library then type in “2000” in the right upper window. Then save picture. Use that picture when you upload, works every time.
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Looks good, is it brighter than the original headlight?
Where did you get the led light?
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Haven't mounted the led bar yet, but that will be much brighter than original. Friend of mine had one lying around, gave it to me. I'm currently driving with a powerful headlamp.
