stingray719
So your saying the gears out of the XF sleds should work in the Vipers? I thought they were different... correct me if I'm wrong.
Oh and what is the stock gears of the XTX?
Stock XTX is 21 top 41 bottom. No idea if XF are the same I ordered Yamaha gears and chain.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
AC sleds with mechanical reverse fit the Viper. I don't know if they are the same manufacturer or ?. But the two stroke that start in the reverse direction are different because the chain case is different!
stingray719
Fit yes, but last year it was said in a magazine article that the Yamaha chain and gears were supposed to be different via being stronger. That may be or may not be true but I bought the Yamaha ones just in case, if you have ever blown a chain at speed you know why
Mtnviper
Vendor
The 7000's use the same Borg-Warner gear/chain as the Viper. The rest of the Cat line up uses a different manufacturer and design for they're gears and chain.
** Borg Warner component - must be used with other Borg Warner components or damage will result.
Bill
Bill
turbo800
- Jul 24, 2014
- UT
- '15 Viper MTX 162 LE w/ MPI 180 turbo
Dumb? Does Borg make the Hy-Vo gears?
Mtnviper
Vendor
Not sure about that, it could be though.Dumb? Does Borg make the Hy-Vo gears?
I haven't looked at the teeth shape to see if they are Hy-Vo cut. If they are, it would explain why they are stronger.
Edit: in my post above I posted a gearing chart with part numbers for reference. Must have been an error in the posting process !
