fourbarrel
Building a collection one sled at a time
I'm making my list of things to do over the summer to my '19 SRX and studding it is tops. Is the T Cat and Winder guards the same? Price wise are they comparable? It seems as soon as that tuning fork logo gets added to the plastic bag the price jumps for a part that's otherwise identical from Cat. What else do I need to put on for protection from studs? I see BOP sells hose covers and wondered if they also should be put on.
Skis..... loaded question I know but what has been the best alternative to the tuner 3s? I've seen posts from guys recommending Curve XS, Slydogs and Pilots, but what has been the best one overall for trail riding over a wide range of snow conditions?
What's the rule of thumb for mileage on shocks before they're due for a rebuild? The Fox i act ones.
Looking at possibly doing a COA kit with a muffler and wondered what kind of a tune needs to be done for that? I'm not shooting for the multi map high hp tunes,just enough to compensate for the muffler and COA kit.
That's enough for now but I'm sure there'll be more later.
Fasttrax
Just installed heat exchanger protectors tonight. Yamaha parts.. $107 Canadian.
fourbarrel
Have a part number?Just installed heat exchanger protectors tonight. Yamaha parts.. $107 Canadian.
Fasttrax
SMA-8LR21-50-00Have a part number?
Fasttrax
What track are you running?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I went with stm products tunnel protectors on my 21 srx.They're a little thicker than yamaha ones and they install by clips not glue like yamaha ones. Also protect they whole underneath and i believe they protect that hose in the tunnel. Pricey 210 us $ but nice. I ordered the tunnel and rear exchanger.
fourbarrel
Likely the stock 1" er.I'd like to go with a taller lug one but will have to wait and see what the budget is come summer if I change it.What track are you running?
most shocks need a refresh around the 2500-3000 mi mark.
i have a set of curves and like them not too bad. they push in mealy snow but managable. only ever ran them with single carbide.
