1st Oil Change for 07 RTX ????
Huntsville, Ontario Canada
Hi Guys just need some insight on what step to take to do a oil change here on a RTX im told once youve done one its easy,if there has been a step by step done maybe i missed it in the search i saw the Ulmers relocation steps is that the way we should go as far as steps ???? Thanks In Advance
Tom
http://www.ty4stroke.com/viewtopic.php? ... e&start=15
look in the tech section and also look at the changing spark plug section I think that showed how to get the sled apart.
Before you start make shure you have a long handle t- type allen wrench #6 to get the clamps loose on the air box. standard allen wrenches are to short.
My best advice is don't be in a hury when you do it make shure you have a couple hours to spare.
changing the oil is simple getting to the filter is a pain in the @##$
Good luck removing the oil filter, Yamaha employs laid off Sumo Wrestlers to install them :die
