wizzard717
- Jan 30, 2007
Is this possible ? I'm installing a skidoo sc5 137 suspension in my 08 and i'm gonna be going to a single ply track therefor i need to change to 2.86 drivers. I assume its just a typical drivers swap...... any input from you guys would be greatly appreciated.
Superman
- Jan 21, 2005
- Gaylord MI
- www.lakeffectsnow.com
Yes, its a simple driver swap. I assume your going with 8 tooth 2.86" drivers. These drivers about 1/8" bigger diameter than the stock 9 tooth 2.52" drivers. (actually its right around .100 thousandths to be more exact) Everything should fit fine.
wizzard717
- Jan 30, 2007
thanks
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
There are 2 ply track available in 2.86" pitch and 137" length. You would be better off going that route unless you already have a single ply track.
Furthermore, if your goal is to use a 137" skid why not run the 136" track with stock drivers (2.52 pitch). You can make the 137" skid work without going to 2.86" drivers and track.
- 7K
