Skidoo 137 SC5 skid in 08' Nytro....need some advice
Thats true but you cant go shorter than a 144 the rear arm will hit. Even with the holz you cant run inside wheels on a 136. (this was all told to me by ice age by mock ups in CAD's)
HOMEHARDWARE65 said:
sleddingfarmer said:
On my xp ski doo the mounting holes line up perfectly. I also install the Nytro skid without any problems too tho...except for the ridiculous weight! I never had to unhook the torsion springs.
i have also been thinking of installing a different suspension in my nytro aswell. are you saying that the nytro skid goes in the xp perfectly with no modifications? if so does that mean I could install an xp skid directly in my nytro, it is a 2008 nytro, I think it is a different tunnel than the nytro se. sorry for the stupid questions, I am a total noob when it comes to suspensions.
Negative, the holes won't line up most likely when you switch from the xp to the nytro. sno-Xr was correct with his explanation.
wizzard717 said:
Lighter, better approach angle, better weight transfer. I came from skidoo and had many of the sc suspensions and they are a piece of cake to get dialed in not to mention they are great when set up for off trail. I'm going to take measurements tonight and if I can do this project without the additions of drop brackets on the rear mounts, I'm going to do it and post pics. Mines an 08 so I have the wider tunnel that might allow me to avoid drop brackets, we ll see.....
Do you have a update for us?
