2 dumb questions spark plugs battery
Paraclete
Belgrade Maine
I have my sled apart to change the plugs. I have taken the 10mm bolt off holding the plug cap on place.
How do I tak that cap off? Does it just pull off or threaded?
Next dumb question
I was going to wire my GPS direct to the battery. Where the hell is it. Lol
Is best to come off a fuse or somewhere else?
Thanks in advance
[/code]
They just pull off, batt is under the airbox. I used the jump leads to make my constant power connections.
You just run a wire from where the jump leads are near the front shock? I guess you could wire an inline fuse right there for easy access.
That is it, small screws in the leads and a fuse forprotection. You can still use the jump leads to start it, and the covers will insulate your connections.
