black knight
I just took my chain case off an 2 thin washers fell out before i could see where they went on for reassembly. i can't find them in the parts brakedown. anyone know where they go. My apex has reveres on it.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I think if I remember correctly the two thin washers which appear silver and also different thickness. Go on the outside of the chaincase. They go on after the disc brakes? Hopefully someone can help you as iam not 100% sure.
Subaru2006
Subaru2006
ROCKRTX
There is one in front of your disc brake behind the c-clip and there is one for sure that always fall is located at the end the reverse gear shaft.( this washer should be shinny)
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
When I took mine apart, the one that went on the small gears inside I want to say that one was actually black.?. Is that possible? Also I was thinking you cant really screw the ones Iam talking about up since shaft size is different..?
Subaru2006
Subaru2006
black knight
When i took the cover off ,the one for the small reverse gears fell off (its black on my machine) and into the oil bucket i had there to catch the rest of the oil. Once i fished it out i cleaned it and put it beside the two silver washers that go on the disc brake. I was sure these fell out of the case when i took it off but i got confuzed. Sorry if i wasted anyone time but you helped me figure out my mistake quiker than i would have on my own.
I think i will need a baby sitter next time.
Cheers
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
No problem thats what this forum is for. Someone helped me before so Iam glad I could help you out. The washers and the brake assembly is under a different diagram.. (BRAKE) You will see those two washers on that diagram.
Subaru2006
Subaru2006
apltx08
Here is the link for the chaincase breakdown...
http://www.yamaha-motor.com/sport/parts/home.aspx
just go to "Proceed with parts cat" bottom right and fill in the info of your model and go to "TRACK DRIVE 2"
black knight
nice, bookmarking that site. didn't even know it exsisted.
thanks aplex08
its back togerther
thanks aplex08
its back togerther
apltx08
black knight said:nice, bookmarking that site. didn't even know it exsisted.
thanks aplex08
its back togerther
Glad you got her back together, give me shout anytime you need help
Where about do you ride? I see your from Ottawa...
black knight
I ride west end of the city. The Beast , K&P, West Carleton Clubs.
P.M. me if you ever need trail conditions out here this winter.
Cheers
Cheers
apltx08
black knight said:I ride west end of the city. The Beast , K&P, West Carleton Clubs.
Cheers
In the coming season we want to ride in your region, we mostly ride Cornwall Seaway, Larose Forest, Hawkesbury and Laurentians (Quebec)
Have a nice summer!
apltx08
