secondary washers
f7lee
sylvan beach, ny
i have an 06 apex rtx and i took my secondary clutch off, but before i noticed the order of the washers on the engine side they fell to the belly pan. when looking at them i noticed 1 is thicker and grooved the other is a plain thin washer what order do they go back on the shaft or doesn't it matter, also does the groove face a certain way? thanks ahead 4 any answers!
One with the groove goes on first, groove facing in towards the motor, then the thin one.
:yam: :4STroke: :rocks:
best thing to do is use a straight bar(i have a 3/8 stock square bar from Home depot) and measure your offset.....
measure by placing a flat bar against REAR TOP part of primary drive clutch extending back towards secondary driven clutch.
measure the distance from backside of primary to backside of secondary,this should be 15mm (+-1mm)
shim accordingly,and typically there is "float" in the secondary.
Dan
\ :4STroke:
just buy the clutch tool from bruce @ pioneer performance and you can measure the center to center also, just my 2 cents.
Just checked my offset. To get it "close" to 15mm, the only spacer I need on the jackshaft behind the clutch, is the thick one with the bearing race relief cut into it. Is this normal, or is my engine mounting way off?
