Have a 2010 MTX and just had the mini 20 amp ignition fuse blow. Looking for a good place to start. Haven't found too many problems with a search. Kinda figuring its either a fluke or have a wire worn through.
680
680
Ultrafrozen
- Feb 14, 2010
- Ontario, Canada
- Yamaha SR Viper
I had the same problem, 500 km on my Phuzzer and the 20 amp IG fuse would pop when I'd hit the throttle. Dealer found a worn/ broken wire in the main harness under the airbox that was grounding out on the frame/ engine.
Biggie
- Dec 29, 2010
- Iowa
- Yamaha Apexs
Take a look around the secondary clutch side area, Heard some guys finding worn wiring there, thinking grey wire sandwiched between the subframe and tunnel area. Not sure if this helps.
