Blowing 20 amp fuse on ignition circuit 09 XTX
cgwiz
NW Lower MI
2009 XTX with 4000 miles and up to now w/o any problems. In UP this week kept blowing the 20 amp fuse on the "ignition" circuit, initially after driving 60 miles, then will blow w/in 2 - 5 miles. Only error code was "81" (handwarmer)??? Managed to limp back to trailer only by replacing with a 30 amp fuse. Any ideas?
Thank you in advance for any input.
Yeah 81 is the handwarmer, shouldn't blow the fuse though. Have you fixed the wire rub issue on the LF of the sled behind the primary clutch? Also put dielectric grease on ALL connections.
