WarriorWithin
I know this is a 4 stroke forum but I was hoping someone here might be able to help me out. My buddy just bought a 2000 sx-r 600 and as far as I can tell it's stock, I took it for a ride the other day and noticed that it rev's over 9000rpm. I have been told that the 600 triple's over rev in stock form but all it needs to fix it is to remove the inner rivet on the primary weights to a heaveir 4.5 gram rivet from yamaha. Now my question is what is the part number for the 4.5 gram rivet? The yamaha site lists 6 different optional rivets but I don't know which one is which? I would really like to get the rpm's down on his sled at full throttle, I get a very uneasy feeling when I see any two stroke snowmobile engine reaching towards the 10000rpm mark!
Thanks for you help guys
How many miles on this sled?
RJH
Just back of the secondary spring one position....more if required.
Turk
Tech Advisor
Been covered a gazzilion times on the 2 stroke side. change inner rivet in the primary weight to a 4.5 gram. Now been covered a gazzilion & one. search feature works awesome for this kinda stuff on older sleds.
WarriorWithin
I am aware that I require a 4.5 gram rivet but I searched the yamaha parts catalogue and it doesn't tell you how many grams the optional rivets weigh. I already searched the 2 stroke forum and was unable to find a part number for the 4.5 gram. If anyone knows what the # is or how I can find it that would be very much appreciated.
Thank you
Thank you
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
The 4.5g rivets for my sled are PN. 90261-06033. Not sure if they would be the same or not.
Brad
Brad
WarriorWithin
Excellent! Thank you very much that is exactly what I was looking for!
Thanks again
Thanks again
