yamsnow69
2003 Rx1 with 136 inch track. on corners the inside ski lifts real easy. What is the correction for that new sway or links or both, If any one has the fix and part numbers that would be great
thanks
thanks
do a search on 13mm sway-bar. that is the most common fix for what you are describing. might want to check cbperfomance's site as they had them listed and are a forumn sponsor/seller.
LazyBastard
You need;
04+ or preferably aftermarket 13mm swaybar,
04+ swaybar links,
04+ swaybar bushings,
04/05 or preferably aftermarket 140 #/inch straight-rate front springs.
04+ swaybar links,
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
I also found that tightening my limiter strap maybe 1/2 inch also helped, but ultimately you will likely find strate rate springs and heavier swaybar are need, as many on here have done....
JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
I have a 04 and i drop a 03 and i noticed the difference. But i can still lift the inside ski on a turn not as easy. I heard guys were lowering the front shocks .5" and getting better reseaults try that.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
yamsnow69,
Please take a moment to update your profile with your location as this is a site requirement.
Thanks,
-1CS
Thanks,
-1CS
BURMAD69
Get used to it no matter what you do you cant eliminate it, you can make it alot better than stock with larger bar longer links, straight rate springs and shortening up the limiter strap.
