Sparky24
- Jan 23, 2019
- Belleville wi
- 2003 RX1
I was riding my 2003 rx1 today and after I got a few miles down the trail the sled started cutting in and out. The sled finally lost power to the dash along with the motor and killed the snowmobile! I then tried to start it and all I am getting is a click at the starter! Any suggestions on what could be wrong? I checked the battery and it’s good, along with the fuses!
smallheadz
- Jun 27, 2018
- Central Ohio
- 05 RX1
I believe I remember reading on here some starters stayed engaged and melted down. Could be something to look at. Can you spin the engine over by hand with the primary clutch? Make sure you didn't have a internal engine failure.
i would charge up the battery and check it 1st as if it is dead, the sled will die like that as well.
Sparky24
- Jan 23, 2019
- Belleville wi
- 2003 RX1
I put a new battery fully charged in the sled and it still just clicks!
Sparky24
- Jan 23, 2019
- Belleville wi
- 2003 RX1
I was able to get the sled started again ran for a bit then died again! The clutch does spin!I believe I remember reading on here some starters stayed engaged and melted down. Could be something to look at. Can you spin the engine over by hand with the primary clutch? Make sure you didn't have a internal engine failure.
starter is piled up then. i do reccomend doing the solenoid while you have it apart as it usually fails not too long after.
Sparky24
- Jan 23, 2019
- Belleville wi
- 2003 RX1
I will do so thanks!starter is piled up then. i do reccomend doing the solenoid while you have it apart as it usually fails not too long after.
