anthony Moccia
- Nov 24, 2019
- Massachusetts
- 2003 rx1
Hello guys, got a question,,
Got a vibration coming from the primary clutch, it snakes the belt, then shakes the secondary, goes through the shaft , into the chain case, rattling the chain, sounds like it's grinding, and sled not even moving,
Stock primary, nothing done to it,,,idk
anthony Moccia
- Nov 24, 2019
- Massachusetts
- 2003 rx1
Ran drag with it yesterday, stock,, but got some holes in air box jetting at 160 main jets, rips to 10k,
I lost by an inch,,,
anthony Moccia
- Nov 24, 2019
- Massachusetts
- 2003 rx1
I think these rivets on the primary clutch weights are making the clutch rattle
anthony Moccia
- Nov 24, 2019
- Massachusetts
- 2003 rx1
I weighed the primary clutch weights and there off like 1,2 milligrams.
i think it is time to pull it apart and check all the bushings in the primary weights and rollers. they do wear.
anthony Moccia
- Nov 24, 2019
- Massachusetts
- 2003 rx1
1 of the weights was .7 mg off, I had 2 sets mixed 1 in,,,,,
Sounds like burnt spot on belt. Put a new belt on, see if problem goes way.
