Lois25
HEY...
I have an 03 RX1 and the other day it wouldn't start.... I checked through as per the service manual and came to the red wire under the tool kit. It was almost broke completely in half. I have done the repair and STILL NO SPARK! Anyone ever have this happen?? I've checked every fuse that I can see!
Thanks!
Thanks!
jtman04401
I believe the fuses that you need to check are on the right side of the sled above the chain case.
Lois25
if you're talking about the one beside the battery ... 30A, its fine... checked it already
Check all your connections and wiggle your ignition switch.
Lois25
I've done that.... how do I test the regulator?
grashoper
- Sep 20, 2010
- Windsor, Nova Scotia
- www.youtube.com
Lois25 said:I've done that.... how do I test the regulator?
Have you checked all the relays?? Including the main ignition relay?
Also, it may not be a bad idea to update your profile to include your location.
Do you have a freind with a sled that is working if so change out the CDI.
crazyyamaha
check the fuses by the coolant reservoir bottle they are located in a little rectangular box .
Lois25
Grasshoper... How do I test a relay? I'm guessing it needs power hooked to it? It's either my main relay or the regulator is my guess...
Lois25
WELL>>>>> I think I found the problem... when the red power wire arc'd on the frame, i think it fried my cdi... I'm getting power everywhere else... I'm going to try and find a used one at a reasonable price and hopefully that fixes the problem...
Lois25 said:Grasshoper... How do I test a relay? I'm guessing it needs power hooked to it? It's either my main relay or the regulator is my guess...
Grasshopper, grasshopper is spelled with two p's. lol Find a CDI and check it out.
grashoper
- Sep 20, 2010
- www.youtube.com
Sled Dog said:Lois25 said:Grasshoper... How do I test a relay? I'm guessing it needs power hooked to it? It's either my main relay or the regulator is my guess...
LOL There's a reason for that... Back in the day when DOS was the operating system of choice, one was limited to 9 characters.... so, i just dropped one 's' and one 'p' and It's been that way ever since!! LOL
grashoper
- Sep 20, 2010
- www.youtube.com
Well, you'd have to get yourself a battery, a couple pieces of wire with alligator clips on each end.... figure out the + and - input.... and multimeter to check for proper output voltage on the proper leads..... Listening for the 'click' is NOT a good way to check for proper operation.... OR... they are pretty cheep ($10- $12) OR just switch them around with another with the same part # stamped on it.. if anybody has a schematic, it will have the pinout for the relays....
grashoper
- Sep 20, 2010
- www.youtube.com
Any updates?? How did u make out so far?
Lois25
been talkin to a tech out here and it looks like the stator... i find it hard to believe but we tried relays, fuses, cdi ... not much else it can be
