MountainMax
- Nov 21, 2004
- Churchill Falls, Labrador
- 2009 Yamaha Apex
Sorry if this is the wrong section,
My passenger hot grips will not work, there is no power at the Orange/black tracer wire at the connector going under the seat, I traced it up as far as the left side of the gas tank and it keeps going down out of site. Anyone know where it goes? Or what feeds it? It’s not coming from the fuse box. And any idea why there is no power on it? Thanks in advance
Did you check the fuses?
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
Y
yes they are all good but this wire I traced does not go to the fuse box, and I don’t have a schematic to see where it goesDid you check the fuses?
Y
Strange.. maybe unplugged someplace.
1st question, was battery fully charged and you where testing at rpm? has to be this way as yamaha made them not to work unless those 2 conditions where met. pissed my buddy off 2-uping back at -30 when the rear warmers where on max and there was no heat because of those 2 things. rockmeister made a replacement relay that made them work all the time. just cannot leave them one when not needed for some reason he told me that i forget. use this kit on my dads 2005 sx venture witch is set up the same way. got hot hands back there now.
