JohnJoe
- Mar 22, 2017
- Alexandria, Ontario
- 2004 Yamaha RX1
I have spark, gas but engine turns and won't fire. It's almost like the timing is off, it backfires and kicks. It resulted so far to strip starter gear, reduction gear,,,one way bearing. When and if it does start it runs fine,,,now seams like it's running lean last time it ran. We checked everything from stator, coils, carbs,wiring, safety switchs,,,and not gaining any ground,,soon I'm afraid we'll dammage the starter gears again because of the kickbacks from the engine. Anybody have any ideas?
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Plugged exhaust?
Dallas4Stroke
- Dec 26, 2015
- Eastern Ontario
- 2003 Yamaha RX1
Need more info, how many miles on the beast...etc...etc?
Sent from my LG-D852 using Tapatalk
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
22000 kms I bought it "not running", we checked stator,,carbs,,all wiring. Now we start it and it runs fine,,until it hits low idlle,,then starts to sputter and stops. When we try to restat it,,it turns and then starts kicking back again. We checked throttle position sensor with ohm meter,,,, I have a mechanic from Yamaha shop with me,,and he's lost. Never seen this problem before. We even took valve cover off and check all timing marks and chain,,, The only "flash" code we gat was low charging system,,but now that went away and no other codes popped up.Need more info, how many miles on the beast...etc...etc?
Pries
- Dec 6, 2015
- Calgary
- 2007 RS Venture
2008 Nytro MTX
I would suggest that you check the camshaft timing. It's possible it's jumped a tooth
Sent from my iPad using Tapatalk
Dallas4Stroke
- Dec 26, 2015
- Eastern Ontario
- 2003 Yamaha RX1
Valves too tight? What's the idle speed?
Dallas4Stroke
- Dec 26, 2015
- Eastern Ontario
- 2003 Yamaha RX1
Just noticed that you are not far from me johnjoe.
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
got all that checked,,,cams,,stator,pick up coil,,carb position sensor,,,compression 155psiI would suggest that you check the camshaft timing. It's possible it's jumped a tooth
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
valves are a pain to check,,,,compression test shows 155 psi cam marks are good with stator,,,Valves too tight? What's the idle speed?
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
idle speed suppose to be aprox 1500,,,if we set it at less then 1800 it idles,,,then misses and dies,valves are a pain to check,,,,compression test shows 155 psi cam marks are good with stator,,,
Pries
- Dec 6, 2015
- Calgary
- 2007 RS Venture
2008 Nytro MTX
Timing chain tensioner was checked to be OK too?
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
without taking the head off,,from top yes the tensioner looked ok,,,Timing chain tensioner was checked to be OK too?
i assume the nosecone wiring has been checked and the coils for arcing?
JohnJoe
- Mar 22, 2017
- 2004 Yamaha RX1
we did have issues with coils arcing when they are pulled out of the holes,,,we changed them,,even took some from other machines but still have signs of arcing. We were wondering if this was a ground issue, since the coils keep working in both machines. Very hard to see if spark arc when coil is in place. Wiring harness was checked for broken wires,,,have no clue if cdi in nose can be deffective. The machine will fire and run,,,but verry hard to start.i assume the nosecone wiring has been checked and the coils for arcing?
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
1984 Phazer (Antique)
I would strongly suggest getting into the carbs and do a very thorough clean and check before jumping any further into chasing internal engine ghosts. I sounds much more like plugged jets - particularly since it won't idle - and I have seen backfiring, etc. from carb issues many, many times. (Do a complete removal of the jets and not just a peek-a-boo taking the bowls down)
- 15K
