actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
In the market to add another 4 stroke Yamaha to the stable. 03-05 RX unless I can find a super Apex deal close enough to home.
Have my eye on a 2004 Warrior. I have not seen it in person and the seller says it won't run OFF choke. He intends to have a dealer clean the carbs and service it. Anything else I should be worried about other than the usual know stuff like bushings, donuts, driveshafts etc?
Thanks in advance.
Thanks in advance.
actionjack
- Apr 9, 2005
Since I am not getting any responses I will ask a more specific question.
Does simply needing the carbs cleaned explain only running ON choke?
Jack
Jack
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Sorry. I was going to do this yesterday and forgot. Yes. The carbs need cleaned. Dirty jets and holes can give a lot of different conditions.
actionjack
- Apr 9, 2005
Thank you
Indy
if it ever runs different than you want, clean the carbs. If it still runs ruff, clean them again.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
As Indy said. If you get good at one thing, it will be those carbs.
