combat
I noticed this past Sunday that the engine seemed to be making a lot of rattling noise. I got home and opened the hood to listen and it sounds like maybe valves or lifters. The sled has 5400 miles on it and has never had any adjusments on these items. It is as noisy at idle as it is at higher revs.Should there have been an adjustment that i overlooked. Any ideas or info would be appreciated. It is not clutch rattle. The sound is directly in proportion to revs.It almost sounds like a diesel clattering. Thanks Combat
yamascoot
- Feb 18, 2011
cam chain tensioner. do a search about this or look at grizztracks thread about this at the top of the rs section.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
x2
Gone Blue
- Oct 11, 2006
- Howell, Michigan
R u sure the noise is not coming from the primary clutch? You can tell pretty easily by putting an ear over the engine cam cover then over the clutch guard. G.B.
combat
Gone Blue: I listened when I first got home at both areas, I even took the clutch gard off to get a better look/listen. It definitly is coming from the engine area across the top where the spark plug caps are. Thanks for any input. Combat
jsjk-4-stroke
my wifes 05 vector is doing the same thing lots of noise , going up to the cabin this weekend to check it & make my list of parts to change the cam chain tensioner at the same time i am going to put in a mono shock suspension. i need to keep wife happy
Gone Blue
- Oct 11, 2006
- Howell, Michigan
combat said:Gone Blue: I listened when I first got home at both areas, I even took the clutch gard off to get a better look/listen. It definitly is coming from the engine area across the top where the spark plug caps are. Thanks for any input. Combat
Bummer man, I would then say to check the chain tensioner like the others first thoughts. G.B.
Roz
combat
Read" Exhaust Valve Tolerance" stream earlier in this fourm. Seams some people are having valve problems with about your mileage. Let me know if it is the valves as I'm trying to see if there is a connection between mileage/VIN's/and valve problems. Too many reports of valve problems with a bullet proof engine.
yamascoot
- Feb 18, 2011
i have had a tensioner on order for 3 weeks. supplier tells me "warehouse" problems on yamaha's end(this was before the tsunami in Japan).
shed
mine was making a similar noise around 6500mi
my first thought was valves
from the consensus it was exhaust donuts
i was going to change them at season end
it turned out to be a valve guide out of spec
it heated up an exhaust valve and it finally
broke off and took out the whole engine
sure glad it was still under warranty
i have 2000 on the new engine
Roz
shed
When you say new engine do you mean a crate motor or did they just replace broken parts. They are throwing parts at mine for the second time, woundering if I should go after them for a whole new motor.
shed
they wanted to just replace the broken parts
they don't have "crate engines in canada"
it was actually cheaper for them to change the whole engine
as the valve took out:
the head
the block
the crank
a piston
they had a "teaching engine" (probably a 2005)
that went into my 2007
i wonder if it had the cam chain update done??
the head
the block
the crank
a piston
combat
2005 Rage with engine noises.
Thanks guys for for all the info. I just got my sled done with a new cam chain tennsioner. dealer said I caught it in time with no other damage. He had just done another sled who wasn't so lucky. The chain slipped on the gear and broke valves and wore the crank down. He said the only thing not hurt were the pistons. Spread the word. Thank You again Yammie guys you're the best.
Regards Combat
Regards Combat
- 7K
