pano
- Dec 30, 2010
My cluster on my sled stopped working. The only light coming on is when the high beams are on. Headlights are working and both fuses by the battery are good. I checked the wiring harness from the cluster to the nose of the sled and it looks good.
LCD/Tach are both off.
Does anyone have any suggestions?
thanks
thanks
Check where it plugs into the cluster for tightness & corrosion.
pano
- Dec 30, 2010
The harness is plugged in tight and there is no corrosion at all.
yox185
Do you have a buddy with one you can try? Viper gauge will also work. If theirs works you know it's your gauge and not wiring.
Honk
check speedo cable where it go's into the end of bearing,bearing may be gone!
montanastick
Your battery may be about dead. When you have a dead cell in your battery the speedo gauge will go zero to 100 then drop to zero intermittently.
Fourcam281
Did you take the beer holder out and check the wires by the bulkhead? They're known to wear through...
- 7K
