rage man
hi i have a 2006 apex was out for last trip when 30 miles in it shut down and wouldnt restart it has power and willl crank but wont start flashes code er1 never heard of it anyone have any ideas
Snowmobileaddict
ECU on the fritz? Check the ECU connections.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
rage man said:hi i have a 2006 apex was out for last trip when 30 miles in it shut down and wouldnt restart it has power and willl crank but wont start flashes code er1 never heard of it anyone have any ideas![]()
Any other codes showing up?
Likely another code there for speedo sensor issue and or TORS.
Disconnect the speedo sensor and TOR's one at a time and see if it will start.
Had the same issue a month ago on my former 06 Apex GT. Ended up being driveshaft bearing was on its way out which messed up the speedo sensor.
rage man
nope did all that no other codes
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Have you weld on the sled.
