NLViper
- Dec 17, 2005
- Paradise Newfoundland
- 2008 FX Nytro RTX
2010 RS Venture TF
2014 PRO RMK Assault 800
Just had a test ride on an 06 Attack. Very sweet machine but just had a question about some bottoming that I felt.
I had the shock set on the hardest setting and on some big bumps it was still bottoming. My dealer told me that it was set for his weight of 160 lbs and I am 215 lbs. He said that it coudl be set for my weight, is this true or will I have some issues with this sled. I am planning on getting an 07 Attack GT so just want to make sure the sled is right for me ( I know the 07 GT has a different shocks as well).
jimmie d
You could not have had it on the stiffest setting, mine is set 2 below stiffest and I am 215 and does not bottom.
Jim
Jim
NLViper
- Dec 17, 2005
- 2008 FX Nytro RTX
2010 RS Venture TF
It felt like it to me that it was on the Max Hard, but I was affraid to push anymore where it was not my sled!
Is it true about setting it up for the riders weight?
BIG BLACK WARRIOR
Jim, He probably had the remote adjuster set in hardest setting, but probably not the shock collar its self.
NLViper
- Dec 17, 2005
- 2008 FX Nytro RTX
2010 RS Venture TF
So adjusting the shock cover will make a difference
Bill
Bill
Turk
Tech Advisor
I am 235 & I moved clip to middle position. It takes a huge bump to bottom my rear skid!
dirkdiggler
Suspended
Why do you want a GT? The Color or the shocks? I have an 06 attack with the bigboy rear spring it it flat out rocks. I was very temped to buy the rear ohlin but after 400 miles I can tell you I don't want or need it.
I also had an opportunity to ride to attacks with the gyrt piggy back fronts on them. I wasn't impressed with them. The stock shocks where more plush.
SO in my book unless it's the color you want the extra money you have to pay for the shocks isn't worth it.
Tork
BIG BLACK WARRIOR said:Jim, He probably had the remote adjuster set in hardest setting, but probably not the shock collar its self.
Yeah, crank the preload up (collar on the rear of the shock, use the spanner wrench)
Not very many complaints on the Attak or ER bottoming, the GT yes, that one needs the stiffer spring if you are much over 200 lbs
y_guy
- Feb 22, 2005
i have a question, how do you adjust the clip for less bottoming? Which direction.. Can anyone detail this for me?
Tork
y_guy said:i have a question, how do you adjust the clip for less bottoming? Which direction.. Can anyone detail this for me?
It is like a 5 position ramp with notches. Go to notches that are further away from the spring. It will be easier to do with the back end off the ground
BigDog05
Be careful with the spanner wrench. It's a knuckle buster.
Sno Cat
It is possible to adjust for your weight, I'm 240# w/the c-clip on the hardest setting, cam is on #4 & only bottom on the worst of bumps.
- Mar 1, 2004
jimmie d said:You could not have had it on the stiffest setting, mine is set 2 below stiffest and I am 215 and does not bottom.
Jim
..SorryBut unless you ride at 25MPH.........It Bottoms Lots, And I've played with mine for about a month now.
YAMAHA CANADA.......On YCN Talks about the spring being UNDER RATED
You need the 5.4KG spring at least or the BIG BOY. Do a poll and you will see how many bottom out reguarly.
