TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
been to a dealer twice for this, now changing dealer
pumps oil into air box severely
it not over filled
dealer replaced oil vent line and oil valve assb. that mtd. on top of oil tank #8ES 520 00 00
it not over filled
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Try Checking the oil breather in the air box for obstructions and make sure that the drain back hose on the bottom of the air box is not kinked or plugged.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
oil in air box
Handy,
can you blow air into air box where oil enters and the hose that is attached to it
Handy,
Handy
- May 12, 2005
- Anola Manitoba
I would remove the air box and clean everything first. I would be careful blowing air through any of the openings. Wouldn't want to damage the valve that the dealer just replaced. On the three cylinder engines a lot of oil goes through the separator / breather in the air box, this oil must flow freely back into the engine, if there are any restrictions the oil would then flow into the air box. I hope this helps. I have an 05 Vector and the only time I had any issues was when the breather froze up during extreme cold conditions with a lot of short rides that wouldn't let all the moisture melt away and after an oil change when I forgot to put the air box drain hose back on to the air box. I think the engine pumped the oil out quicker than I could pour it in.
