BigJeffMN
Sled started in morning cold, ran warmed up moved it to get a truck out. Friend turned sled off but left key half on went to start hour later no go. Let sit no go, noticed fuel pump not cycling only a click like it is turning on but no cycling noise. What I'd the possible problem? Fuse, flooded, needs to sit. Please help big trip Friday. Thanks in advance.
gcr3903
- Jan 31, 2007
- Phillips, WI. - U.S.A. -
- 2004 RX-1
Dead battery, bad connection/ground.
BigJeffMN
It cranks fine never pops over. Where to look for ground issue
ROCKRTX
Check gas pump relay and tell us battery voltage.
BigJeffMN
Do you know where the relay is
ROCKRTX
take off left panel and check were you place your feet....up there
BigJeffMN
This thing boggles my mind! So we got it on the trailer and after I got home everything was fine, pump cycled and sled started no problem.
Was this truly low battery because the key had been left in the first on position for so long? With a low battery the sled will crank fine but the fuel pump is not going to cycle?
I am glad it started but I am lost as to exactly why this happened. I will have to hold a class for the guys I ride with if they are going to start or move my sled. I know I am going to get crap for that.
