durn
- Dec 16, 2014
- 2007 attak
Hello All, newbie here. Started up great in august, went to garage last week, turns over, no fire. Fuel pump not spooling up. Changed over to red relay, still no action. Put original back in and can hear relay clicking. Lots of battery power, checked all grounds as per other posts here. Don't have a wiring diagram, and still no pump. All fuses ok, including the 10 amp beside the battery. No corrosion on connections at solenoid. If the positive wire to the fuel pump is red with blue and found at a connection above the secondary clutch (heading back towards the tank), I checked voltage there and have .01V. Until I get a wiring diagram, any suggestions?
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
Welcome to the forums.
Does your dash light up?
Does it flash any codes?
durn
- Dec 16, 2014
- 2007 attak
Yes, lights up, no codes. Just checked voltage at connector above secondary clutch to fuel pump. Had battery voltage during "spool" up time. I guess next is to check under seat. I'm thinking mice maybe?Welcome to the forums.
durn
- Dec 16, 2014
- 2007 attak
Yes it was mice. Pulled the seat and a big nest on the fuel pump, both wires chewed, works great now. ThanksYes, lights up, no codes. Just checked voltage at connector above secondary clutch to fuel pump. Had battery voltage during "spool" up time. I guess next is to check under seat. I'm thinking mice maybe?
wavemaster
- Mar 6, 2009
- New Hampshire
Sweet. Nice find, I'm glad you have it back up and running.
good you found it.
