wichie13
- Dec 31, 2017
- bowmanville
- phazer fx 2007
Just bought this machine used and is slow to start. wouldnt start in the -17 weather yesterday. I read talk of a cold start ecu and I have a feeling this machine never got the recall but think new plugs would help. So my question is where are the spark plugs and how easy is it to change them? Any videos or photos would be a great help. As well is the oil change really the nightmare some you tuber said it was? I have no idea when it was last done.
I'm a handy guy but a newb to sleds so be kind. Thanks
wichie13
- Dec 31, 2017
- bowmanville
- phazer fx 2007
found this thread google search is better than the forum search. anyone done a video on this?
https://ty4stroke.com/threads/how-to-change-spark-plugs-please-help.94423/
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Not sure about a video but it’s really not that bad once you’ve done it a few times.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Call your local dealer with the VIN number and they should be able to check if any/all the updates have been done. That said, My phazer turns over pretty slow below 0*f, even with a new battery, anything colder than -20*f it usually won't go or I have to boost it with a big battery. The factory battery sizes is pretty small, IMO, for a twin cylinder that needs to start in frigid temperatures. My Rancher 420 uses the same battery and that turns over very slow below 0*f also.
Jan Hohmann
- Jan 3, 2018
- Grand bay-Westfield
- 2007 yamaha phazer fx
I am.brand new to this site as well brand new to.my 2007 phazer. Changed spark plugs myself a couple weeks ago. Job seemed ominous, but ended up doing it and it was fairly easy. Even removing fuel tank which has to be done. I' concerned about the oil filter change
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
And unless you work on Yamaha sleds daily, you should never have to do it a few times. Unless you start and shut the sled off cold, the plugs don't foul out like a 2-stroke. I sold our phazer with nearly 5000 miles on it with the original plugs in it. Let's be real -20 is damn cold, plain and simple.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
True, you really shouldn’t need to change them often if you always let them warm up properly. I’ve found the worst culprit for plug problems is when it’s cold and there stale gas in the tank.
That said, I have being doing maintenance on my Phazer plus two other Phazers for over 10 years so I have done it a few times.
I have just over 6k miles on mine with the stock plugs.
wichie13
- Dec 31, 2017
- bowmanville
- phazer fx 2007
Thanks everyone
