2007 venture -no electronics and wont start but spins over
V-maximum
Robinsons,Newfoundland
Went to start it up today, the engine will spin over but no lights, no electronics on the gages no lights anywere on the sled. Drove it in the shed last winter never touched it after. Its almost like a blowen fuse except they are all good. Very strange, it wont start or make an offer just spin over :o|
You shouldn't get any lights, until it starts up. Mine took quite a lot of cranking, to start this fall. The fuel needs to fill the carbs, before it'll fire. Just don't crank it over, for more than 10-15 seconds at a time. Good luck.
So all you hear is the starter spin?
Could be a busted flex shaft?? i know my old sled had a flexable shaft from the starter to the clutch that engages the starter. if you understand what im trying to say or it could just have gears, not sure.
You should hear the engine turning over even thought it might not be fiering.
Re: 2007 venture -no electronics and wont start but spins ov
Are you saying the Starter will not engage the engine to start it? The starter motor sounds like it is spinning, but the engine is not turning over. Is this what you are saying?
If yes, did you charge the battery? Batteries need to be charged monthly during the summer storage period.
battery
I had an 06 Nytro two years ago that did the same thing. I tried to charge the battery and that did not work. Have your battery tested, it might not hold the charge. You might have to replace the battery all together. (I did)
My vote is for the: Battery
