V-maximum
Went to start it up today, the engine will spin over but no lights, no electronics on the gages no lights anywere on the sled. Drove it in the shed last winter never touched it after. Its almost like a blowen fuse except they are all good. Very strange, it wont start or make an offer just spin over
newyorker_79
You shouldn't get any lights, until it starts up. Mine took quite a lot of cranking, to start this fall. The fuel needs to fill the carbs, before it'll fire. Just don't crank it over, for more than 10-15 seconds at a time. Good luck.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
So all you hear is the starter spin?
Could be a busted flex shaft?? i know my old sled had a flexable shaft from the starter to the clutch that engages the starter. if you understand what im trying to say or it could just have gears, not sure.
You should hear the engine turning over even thought it might not be fiering.
Len Todd
Re: 2007 venture -no electronics and wont start but spins ov
Are you saying the Starter will not engage the engine to start it? The starter motor sounds like it is spinning, but the engine is not turning over. Is this what you are saying?
If yes, did you charge the battery? Batteries need to be charged monthly during the summer storage period.
V-maximum said:Went to start it up today, the engine will spin over but no lights, no electronics on the gages no lights anywere on the sled. Drove it in the shed last winter never touched it after. Its almost like a blowen fuse except they are all good. Very strange, it wont start or make an offer just spin over![]()
MattMac1
Second on the battery. Had similar issue on my warrior.
dox06
- Mar 25, 2007
- Jackson, Michigan
- 17 SW XTX SE
17 G4 Gade 850
battery
I had an 06 Nytro two years ago that did the same thing. I tried to charge the battery and that did not work. Have your battery tested, it might not hold the charge. You might have to replace the battery all together. (I did)
My vote is for the: Battery
- 10K
