The Dude
Just took my Phazer in for the 3 tech updates, new hot grip harness, ground block and A arm ends. My question is, does the new hot grip harness really fix the grips, they did work before but definitely not good enough. I'll be testing it out this weekend so they'll either do the trick or it's Yamaheaters for sure.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I installed the updated wiring for the grip warmers last year on my 07. What a difference! I never have them above 3!
The Dude
That's definitely some good news. I do use gauntlets when it's really cold anyway, but it's been real chilly here lately and -20 F and lower the current grip warmers thick gloves and gauntlets just aren't cutting it, at all! Thanks for your reply!
nobrakes
Wait a minute.. there is a hotgrip harness update??
Was there a bulletin from Yamaha on this or is this something as an optional addon?
Mine are WEAK WEAK WEAK on an 07 standard
Cubby
- Dec 14, 2009
nobrakes
niiice! Thanks for the actual bulliten
I gotta mention this to my dealer.
Cubby
- Dec 14, 2009
I have all the bulletins for the Phazer. If you want them let me know (the files are large). They are:
TSB 2007-001 Front Suspension Upper Arm Ball Joint Nut tightening
TSB 2007-006 Steering Idler Arm Nut
TSB 2007-007 Air Intake, Engine Mount, and Air Intake Snow protection
TSB 2007-011 Cold Start ECU update
TSB 2007-012 Insufficent heat output from Grip Warmers
TSB 2008-005 Close Rear Tunnel hole additional heat deflectors
TSB 2008-007 Loose and Noisy Front Suspension Lower Arm Ball Joint
TSB 2009-004 Shifting in Reverse Difficulties
TSB 2009-008 Ground Failure at Joint Connector
xt_gt
Cubby said:I installed the updated wiring for the grip warmers last year on my 07. What a difference! I never have them above 3!
same here, you put them any higher you can start to smell your gloves.
tmac220
Cubby said:I have all the bulletins for the Phazer. If you want them let me know (the files are large). They are:
Could you Post the TSB 2009-004 Shifting in Reverse Difficulties Bulletin?
tmac220
I have a 09 RTX and even with Gauntlets the Hand Warmers are not nearly as good as any other sled I've owned
Cubby
- Dec 14, 2009
Hi Tmac220. Its too big to post here - 1.8 MB. Please PM me your email address and I will send it to you. I have the shim installed this year as last year I was having intermittent issues getting into reverse - even with the new belt. So far its working this year.
The Dude
The part # for the grip warmer harness on the receipt is 90891-50150-00 and it was a warranty thing don't know if all years are covered though? Supposedly it changes the wiring from being in series to parallel ?
Other issues include the reverse, ie, hard to get to go in and out of, but no trouble so far this season, am running the chain looser and the belt has 1000 miles on which may or may not help, but it's working good this season so far, it was a Big problem the first year.
The Dude
Tested the sled this weekend and I can say I now have hot grips that work! Yea! Temps were -20 to 0 ish and I was turning them down.
Machinist
Does this update apply to Canadian models? Cubby...you're from Winnipeg so you've done it. I haven't seen that service bulletin on Yamaha Canada's website. Does the harness apply to our sleds and can you order it from a Canadian dealer or did you order it from the US?
Cubby
- Dec 14, 2009
The bulletin applies to 08 but i installed it on my 07 with no problems. I bought the update from my local dealer for $12. Both local dealers i called had them in stock.
- 32K
