bwilly
I see Fix Powersport sells a "Mid-wheel" kit, and also Yamaha OEM sells a marginal snow kit. Is anybody using these? are they the same thing? Do they really help with Hyfax wear?
http://www.fixpowersports.com/pages/cus ... l-kit.aspx
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I have their MID and FRONT wheel kits...they will save your sliders on these areas.
you can get replacement wheels(2.75") when you need to replace the rubber....also they come with replaceable bearings(5/8" ID) http://www.mfgsupply.com/m/c/04-116-62.html?id=SC3ABJmI
I like them.
Front wheel kit
mid wheel kit
I like them.
Front wheel kit
mid wheel kit
AttakSnow2
- Aug 17, 2005
- Merrill, WI and White Pine, MI
- Yamaha Viper
I have the OEM mid kit mounted on mine. They do seem to help. Same as above, I have them mounted on the inside as well. The OEM lets you mount them on the inside or outside the rail.
grumpysanta
little wheels
they work to some extent but you have to check the bearings more offen as they spin much more than bigger ones
tryanATTAK
- Mar 6, 2007
- Scotts, Michigan : Southwest lower
I have them on my 07' Attak and have over 4,000 miles on the hyfax that is currently on and they look almost new still so yeah I say they work.
I had them mounted on the outside and then moved them to the inside but they didnt last running over the studs. Bought new wheels and moved them back outside. Mine are the Yamaha mid mount wheels. Fix kits cost about 20.00 more.
tryanATTAK
- Mar 6, 2007
OOOOOppppSS sorry mine is the Pioneer marginal snow wheel kit and the small front wheel kit.
