tomseal6
- Aug 23, 2006
- Brevort, MI
- 4 strokes
Check for corroded contacts in wires to pump relay
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Ok everyone here is a bit of a update. I am getting spark and the fuel pump is pumping fuel. I swapped out the computer with my buddies. I also unhooked the power commander and went back to the original plugs. It’s like something is telling the injectors not to feed fuel once I try to refire it. Is there a throttle position switch that would cause this or maybe a crank sensor? Worked on it with 2 other buddies and it has all of us stumped. Would a stator or pick up coil cause this?
wolfe9904
- Dec 29, 2013
Also, the weird part if the sled sits for a while a day or longer it will fire up , but once you shut it off it will not re-fire????Ok everyone here is a bit of a update. I am getting spark and the fuel pump is pumping fuel. I swapped out the computer with my buddies. I also unhooked the power commander and went back to the original plugs. It’s like something is telling the injectors not to feed fuel once I try to refire it. Is there a throttle position switch that would cause this or maybe a crank sensor? Worked on it with 2 other buddies and it has all of us stumped. Would a stator or pick up coil cause this?
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
So it starts cold, but won't restart after warmed up? And it shut itself off on the trail, so should have been at operating temp at that point. I assume you checked for spark after it was warmed up? Also checked that the injectors are getting are getting power when warm? Sounds like a component is either failing, and only has a problem warm, or the ecu thinks the engine is overheating. I have a Venture ( two stroke) that had a bad stator and would quit on the trail, but would restart when it cooled down.
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Correct Keith, starts cold but not warm. I dont know if the spark I check was after it warmed up or not. We messed with it all day today. I didnt check for power at the injectors. I don’t know if I’d know how to do it. Might have to do some research on it. Can you test a stator? Thanks for the input.So it starts cold, but won't restart after warmed up? And it shut itself off on the trail, so should have been at operating temp at that point. I assume you checked for spark after it was warmed up? Also checked that the injectors are getting are getting power when warm? Sounds like a component is either failing, and only has a problem warm, or the ecu thinks the engine is overheating. I have a Venture ( two stroke) that had a bad stator and would quit on the trail, but would restart when it cooled down.
Keith1962
- Mar 26, 2015
- Camillus, NY
You should get 14v to the battery at 5k rpm. Never disconnect the battery when the engine is running or you will kill the voltage regulator. If you dont have power to the battery, check the main fuse. If the fuse is good, and no or low voltage at the battery, you need a stator. You need a service manual. You can pull down a pdf copy, or pm your email address, and I can send you one.
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Ok another update, I swapped out some pretty black plugs with some new ones and it fired right up. While running we checked the stator as discribed and was getting. 13.8v (belt didn’t like it though). Shut it off and it did restart, Not good but did restart. Let it idle for a bit and it stalled and would not fire back up. We rechecked for codes and I got a 12 which seems to be the crank sensor. I didn’t get a warning light or anything on the gauge pod for the code, we just read how to check them and did it. Now is the crank sensor and pick up assembly the same thing? It’s behind the primary and held in with a Allen head? Thank again everyone.
Keith1962
- Mar 26, 2015
- Camillus, NY
Code 12 is the crank position sensor. Yes, it is what tells the ignition when to fire. Sounds like you need one. Part number is 8GL-81670-00-00. It is behind the primary clutch. Easy fix. Also check the wiring harness for a rub through where it is routed by the front engine mount right behind the clutch.
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Yes not that hard to replace but really hard to find one. On back order till March 13, just my luck. Thanks for your help and I’ll send you a update when I get one.
Keith1962
- Mar 26, 2015
- Camillus, NY
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Yup I’m calling them today to see if I can get one over nighted. Good news is they are in NY too. It’s a boat place haha.
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
So the boat place was a no go, had non. I called 26 dealers and nothing. Ended up having to go with a used one on eBay and pay $85 for overnight shipping. We went and tested it but it seemed to test ok. It was cold in a garage and measured low 400s, hit it with a a hair dryer then held it in my hand and was within the 445-545. My buddy was thinking being in the block it will get a lot more heat and thinks it could cause a open circuit when it gets hot. Could this happen? I’m thinking if this doesn’t fix it it’s going off to the dealer.
Keith1962
- Mar 26, 2015
- Camillus, NY
It could happen, that what is wrong with the old one. Try your "new" one and see. I'm not a big fan of a used one considering they are a known problem.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
any place that has 9, has none. As far as I know there has been very few failures and that is why its backordered. I get used stuff all the time in that situation, quicker than new. At least it actually exists and they are not just wasting your time. But if it reads good, I bet its fine
Phatboi99
- Sep 24, 2015
- Buffalo ny
- 08 phazer
Well it did happen to be the the crank sensor we think. It starts up, runs, restarts, doesn’t stall. We restarted about 6 times. I took it outside and did some hot laps in the yard and no issues. Fingers crossed it’s fixed. Going to old forge tomorrow. We’ll see. Thank you everyone for your help and info.
