Groomer08
stud her up!
just finished breakin my xtx in. and all i can say is STUD IT!! im doing like 96 up the middle or whatever it is for this track 104?? double backers, as short a stud as i can go.
I almost lost it quite a few times, if i wasnt as good a rider as i am, the sled def would have went over this weekend. any sort of ice and the track and skis want to swap ends because of the engine braking and/or track slippage. its not cool. I was in maine, the lakes had very little snow on them, and the trails had lots of water seepage that had frozen.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Re: stud her up!
No...For the XTX it is 114 down the center and you're ready to go...
Groomer08 said:just finished breakin my xtx in. and all i can say is STUD IT!! im doing like 96 up the middle or whatever it is for this track 104?? double backers, as short a stud as i can go.
Groomer08
ah yes
i knew there was a 4 in it. 114 thats what it was! yup im going that route!!! picking as short a stud as possible to avoid any issues with undertunnel. checking a buddys sled today to see if i can get away with 1.25"(mine is in maine still)
SledFreak
- Feb 7, 2005
- Ontario. Canada
Run no less then 1.325 or 1.375. That is the recommended height on studs for the Nytro/XTX models. If you are going to run a shorter studs ( you are wasting your money) and then you might as well just change your track to the ice ripper sharp XT track. That would be a better option, then going with a very low stud penetration.
Sno-Xr
I agree. I studded mine with my used 1.075's. I have about 1/8 penetration, which helps, but will deffinitly go longer when these are wore out.SledFreak said:Run no less then 1.325 or 1.375. That is the recommended height on studs for the Nytro/XTX models. If you are going to run a shorter studs ( you are wasting your money) and then you might as well just change your track to the ice ripper sharp XT track. That would be a better option, then going with a very low stud penetration.
