zr8000
- Dec 29, 2005
I would like to know the stock cluching for this sled.
I cannot find a post with this information?
Primary spring
Weight
Heel rivet weight
Middle rivet weight
Tip rivet weight)
Secondary spring
Helix
Wrap
Primary spring
Weight
Heel rivet weight
Middle rivet weight
Tip rivet weight)
Secondary spring
Helix
Wrap
paradise710
Go to www.yamaha-motor.ca "english" then "snowmobiles" then "Parts Catalogue". Launch the application and enter your info about the sled you have. It will tell you most information. You just have to search for it! Hope this helps!
larrypolaris
Saved this a while back.
08 & 09 FX Nytro Standard & RTX:
Primary Spring: Y-S-Y
Rollers: 15.6mm
Weights: 8GL00
Inner: 4.5 gram
Middle: 4.5 gram
Tip: 2.4 gram
Secondary Spring: Pink
Helix: 43*
Wrap: 6-2
09 FX Nytro RTX SE:
Primary Spring: B-W-B
Rollers: 15.6mm
Weights: 8GL00
Inner: 4.5 gram
Middle: 4.5 gram
Tip: .8 gram
Helix: 43*
Wrap 6-1
09 FX Nytro XTX:
Primary Spring: B-S-B
Rollers: 15.6mm
Weights: 8GL00
Inner: .8 gram
Middle: 4.5 gram
Tip: 4.5 gram
Secondary Spring: White
Helix: 43*
Wrap: 6-1
Rollers: 15.6mm
Weights: 8GL00
Inner: 4.5 gram
Middle: 4.5 gram
Tip: 2.4 gram
Helix: 43*
Wrap: 6-2
09 FX Nytro RTX SE:
Rollers: 15.6mm
Weights: 8GL00
Inner: 4.5 gram
Middle: 4.5 gram
Tip: .8 gram
Helix: 43*
Wrap 6-1
09 FX Nytro XTX:
Rollers: 15.6mm
Weights: 8GL00
Inner: .8 gram
Middle: 4.5 gram
Tip: 4.5 gram
Helix: 43*
Wrap: 6-1
paradise710
I'd be interested to know what you plan on doing with your clutch set up! I've looked into a few kits, just thinking a few inexpensive stock mods might get where I need. Nobody seems to like experimenting with stock parts, then again, $300-$400 bucks gets you a very good aftermarket kit. Stock set up is decent, but always has room for improvement!
zr8000
- Dec 29, 2005
Thanks for the information.
I actually purchased and installed a schmidt bros stage 2 kit in my wife's 2009 XTX. I have typically came up with my own setups for previous sleds but thought that I did not want to spend the time this year.
I wanted a smoother engagement and better performance in a bolt in kit.
Eventually, I will experiment to see if I can make improvements for specific conditions which is why I needed the stock setup to understand things better.
As you can tell, I plan on riding this XTX quite a bit. It won't be as fast as my Arctic Cat but I think I will really like it!
