natedogg3
I know this has been discussed a number of times, however im still going to ask.
I am looking for a clutch kit that is going to give me the best off the line and mid range throttle response!!
currently looking at D and D, Bender, Schmitt Bros. and have made numerous attempts to speak with Nate at Boss performance.
anyhow, let me know your experiences/thoughts.
thanks in advance.
thanks in advance.
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
any of them are prolly good,im gunna go with ulmers,i have the same exact sled
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
check hartmans
Ulmer Racing will set it you up right. Ask's your weight, and riding style. Ships it to you ready to rock. Simple as that. Also, it flat out works!
larrypolaris
Had both Ulmers & Hauck's.
Currently running Hauck's.
Both give good gains & tuneabilty. Some slight driveability differences between the two.
shadow44
Drag n Flys with Turks black spring set up is awsome! If you don't care about top end it's the perfect set up.
nor'easter
- Feb 12, 2008
- Pennsylvania
- Nytro RTX SE
With the Schmidt Bros. kit, the low engagement allows for very smooth take - offs. You gradually press the throttle and the sled moves forward very smoothly. Their stage II helix really gets you moving in the mid range.
natedogg3
shaddow44 said:Drag n Flys with Turks black spring set up is awsome! If you don't care about top end it's the perfect set up.
Im a former ski doo guy. So, i have seen lots of discussion about these Drag n flys.
what are drag n flys?? are they a weight set up?? where do you purchase them??
natedogg3
I would like to set up my xtx to run with my buddies ski doo 1200.
am i dreaming or will the nytro run with the ski doo four stroke?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
natedogg3 said:I would like to set up my xtx to run with my buddies ski doo 1200.
am i dreaming or will the nytro run with the ski doo four stroke?It may take more then a clutch kit to Run with XR1200. I have a very well setup XTX and recently picked up a 1200 so it won't be long...
The single biggest mod you can do IMO to XTX is install 1.450" studs, not 1.325".. There is a huge difference in holeshot and acceleration just in slightly longer studs and it's well worth it.
natedogg3 said:shaddow44 said:Drag n Flys with Turks black spring set up is awsome! If you don't care about top end it's the perfect set up.
http://heelclickerclutching.com/snowmobile/yamaha/drag-fly-primary-kit.php
BADSLED
- May 13, 2004
- Syracuse, NY
If you are looking to get the best performance gains out of your clutch kit go with the 2 speed weights! Pm me with any questions....
natedogg3
BADSLED said:natedogg3 said:shaddow44 said:Drag n Flys with Turks black spring set up is awsome! If you don't care about top end it's the perfect set up.
Great thanks , ill be in contact!
