musselmark
I have a 2010 vector and recently bought some aftermarket idler wheels for inside the rails (#3 position on many diagrams) the shop gave me 135mm wheels and my stock ones are only 130mm. The 135mm are approx 1/4" below the hyfax. Will these work or should I get the smaller ones. An aftermarket catalog I have (royal distributing) lists both, 130mm for position 3 all 4 strokes '03-'13 and 135mm for position 3 for all 4 strokes '09-'15?????. These wheels seem to disintegrate every year, is that from rolling over the base of the studs?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
135mm wheels will help with slide wear as they will take some weight off the slides. Lots of guys run the larger 135 mm wheels. They will work fine. The stock wheels are 130mm. Inside wheels do tend to get chewed up from the studs. Make sure you don't have a bent or loose stud that isnt' sunk into track as that will destroy wheels quickly.
