dexter
Had my shock revalved by pioneer and just getting out to ride it. Thing bottoms out all the time even though my spring is max hard. Are there clips on the shock body to adjust? Obviously there is more to adjust as it is just way to soft and the clicker works fine. Help!!!
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
You need to compress the spring and move the circlip on the shock body to the second or third position. Many replace the spring with the heavy duty replacement as well.
dexter
Ok...thanks which setting do u run? I wonder if the thirs would be too harsh.
thrasher
- Nov 22, 2006
- 06 Vector RS ER
On trips I run with a total of about 300lbs. Have monoshock revalved with a pioneer heavy duty spring, second circlip position with shock cam on the fourth position. RA set at the 11 click for me. The RA cable usually breaks about mid season, so this set-up is generally good for me.
