2010 Vector
superb
Ottawa, Ontario
Canada
2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
What rpm should I be turning with my 2010 vector gt short track? It has an excel header with stock exhaust,ulmer clutch kit and geared down 1 tooth. Thanks in advance.
That would depend on how fast you are going/load weight/snow conditions/ etc unless you mean at idle?
VECTOR
My Apex makes the best possible power between 10500 and 10800 and I would like to know where to clutch my Vector at, what rpm does it make the best possible power at. Thank-you
Vector should run 8500-8800 MAX
It's direct clutched, where-as the Apex has gear reduction. IMO, the stock clutching is pretty damn spot-on.
Its a 2010, so fuel injection.....which stock likes about 8250. but with the header pipe, 8400-8700.
