Nytromchi
Hey guys i have been having problems steady with breaking suspension parts and things rubbing. had to replace front and back shock last year as well as from arm on suspension and two bars that run beside the back shock twice. The new front arm didnt last long before the two loops on top were broke off and excessive rubbing on it as well as front and back shock both have rubbing. Also hard on wheels. Anyone have this problem or know what maybe wrong?
As well i am currently looking for a complete xtx skid to try see if i have different results. PM if you know where i would find a second hand one.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
Nytromchi said:Hey guys i have been having problems steady with breaking suspension parts and things rubbing. had to replace front and back shock last year as well as from arm on suspension and two bars that run beside the back shock twice. The new front arm didnt last long before the two loops on top were broke off and excessive rubbing on it as well as front and back shock both have rubbing. Also hard on wheels. Anyone have this problem or know what maybe wrong?
i havent had nearly the problems that you ae faced with. What is your rider weight? Do you do a lot of ditch banging, etc? My rider weight is 220lbs and I have added alot ponys to the powerplant. The only thing I have done to my skid is aftermkt wheels (Slydogs), 4th wheel kit and heavier springs...
Nytromchi
I am 195 do some ditch banging but not excessive. Run mostly groomed trails. I do ride hard but suspenstion shouldnt be taking the beating it does. I also have the MPI stage 2 supercharger.. Track has 4 studs per bar. So lotsa studs.
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Studs are probably rubbing your front shock.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
SSX600 said:Studs are probably rubbing your front shock.
what he said ^^^^^ do not stud in the center 1.5" of the proaction skid!
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
**sj** said:SSX600 said:Studs are probably rubbing your front shock.
X3
