macpat
- Nov 6, 2009
- South Porcupine, ON
- www.gotsnow.ca
Does anyone know what the major differences are between the 2010 XTX and the 2011 XTX??? Does not seem to be many differences in comparing both on the Yamaha website?
Thanks!
Thanks!
Just colors....
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
Go ask on the Yamaha Blog. While the specs may be the same, there's always suttle changes/improvements on certain parts quality, etc.
macpat
- Nov 6, 2009
- www.gotsnow.ca
Yellowknife said:Go ask on the Yamaha Blog. While the specs may be the same, there's always suttle changes/improvements on certain parts quality, etc.
This is more along the lines of what I was trying to get at. Did they improve anything on the subframe, skiis etc...
Will try the Yamaha blog but if anyone else has other insight that would be good.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I believe the 2011 runs the same subframe as the 2010. They say the subframe gussets are stronger but I don't believe it. I installed my own gussets in a new 2010 frame after hearing reports about it bending also. I believe Yamaha's center gusset is placed to low in the frame and adds no additional support to the a-arm mounts. Maybe Yamaha will pick up on this and come out with a fourth update.
My Fix:
http://www.ty4stroke.com/viewtopic.php?t=87758
My Fix:
After much research I found just colors....
